rear end question
RE: rear end question
10 bolt rear ends are week, sooooooooo the whole thing. look for a ford 8.8 if possible,
if you have an eaton gov lok, well, there also known as the grenade lok and a gov bomb, self spoken[8D]
If I'm not mistaken the "rear end" refers to the unit that spins your rear wheel axles. It's located in the carrier assembly that connects to your drive shaft. The carrier assembly houses both your left and right axles and the differential assembly (rear end). You want to upgrade it when you put a more powerful engine in because if the assembly, whether it's the differential or the carrier assembly, can't handle the power. You can run the risk of it blowing up, grenading on you what ever you want to call it. Like Abyliks says look for a ford 9 inch or 8.8 rear end. They can handle much more torque then the stock 10's. As far as gear ratio I would look for 3.73's or 4.11's. With the "rear end" you want to look for a limited slip differential to spin both wheels when you give her some gas. I hope that helped a little and if any one else has more info please post. I what to learn to
why are you going to put a Ford rear end in a Chevy? pfftt , get a Currie built 12 bolt and keep your chevy , all chevy! the 12 bolt chevy rearend will handle anything you throw at it and you put more power to the ground with a 12 bolt because the ring gear is lighter. It's not as simple as "bolt in a 9" , the rearend in 3rd and 4th gens uses lower control arms , a torque arm , and panhard bar. you can get a 12 bolt from Currie Enterprises with any gear ratio you want , disc brakes , and a limited slip diff. ready to bolt in.
So in this picture is it the spherical structure in the middle of the axel?
http://members.aol.com/pullingtracto...s/pintrear.gif
ORIGINAL: asdfghjkllkjhgfdsa
Before jumping to conclusions on the previous posts. What year and engine type do you have??.
usually when people say "rearend" they mean the complete rear differential assembly (everything in the picture), the differental , the axles , and axle tubes. the acutal differential is where the gears are, there is a ring gear (the biggear shaped like a ring in the picture) a set of "spider gears" (real name isside gears) that attach to the axles, a pinion gear (the one connected to the drive shaft via a yoke) , and a carrier (which is what the ring gear bolts to and houses the side gears). if you have a Limited slip there will clutches or cones instead of side gears but all the other components are the same.
Alright I just got my 87 2.8 and I'm in the planning stages.
I'm only 16 so I have to do everything little by little.
I want to drop a 350 in it and stuff (to be announced) but my final goal is to end up with around 350HP idk how much torque though...
if your just wanting to make 350hp , you should swap a complete rearend from a '89 up F-Body , they have a larger ring ring gear and 28 spline axles instead of 26 spline. the 89 rear diff. will hold more power than the '82-'88 rearend as long as you don't beat on it.
