Rear end conversion
Old 10-27-2006 | 04:01 PM
85z285.0's Avatar
Default Rear end conversion
I have a 1985 z28. It's a 5 speed and a one legger with drum brakes. I'm looking to change it over to posi rear and disc brakes. If a rear end from a newer camaro can be installed what years? Also, How difficult is it to change?
Old 10-27-2006 | 07:36 PM
350rs's Avatar
March 2008 ROTM
Default RE: Rear end conversion
if i were you, id just look for a wrecked IROC or something that has it from the same gen, I.E. 3rd gen, look for a 3rd gen rear end.
Old 10-27-2006 | 07:44 PM
MadMikeZ28's Avatar
You could also look at 82-92 firebirds. A GTA would be a good place to look under for a Dana. I am not positive, maybe someone can confirm, but I remember reading in a magazine that the fourth gens are the same also.
Old 10-28-2006 | 03:56 AM
85z285.0's Avatar
Thanks I figured that would be the best bet.
Old 10-28-2006 | 03:57 AM
85z285.0's Avatar
Thanks for the info. I was figuring that would be the safest way to go.
Old 10-29-2006 | 02:03 AM
gray89vert's Avatar
Actually a fourth gen rear end will work too. They are easier to find with disc brakes. I have swapped the rear end in my car. Its pretty simple. Just unbolt the torque arm, lower control arms, the shocks, brake lines and it will drop right out. The only difference in the 4th gen rear end is that it is 2" wider. Not a huge difference and you would only be able to tell if you looked. The tires wouldn't stick out extremely bad or anything.
John4649
10-12-2012 05:12 PM
Z28inAUS
01-10-2011 02:00 AM
DJAbby
67-69 V8 Tech
01-08-2009 07:55 PM
CamaroKid16
11-29-2007 01:01 PM
85z285.0
08-15-2007 09:55 AM
