rear end change
rear end change
I have the stock rear end in my 89 RS, its posi and i would like to keep it. but i was looking to get a 3.73 rear end. can i just buy the gears and whatnot, put them in, and keep the posi? or is that part of the gears or what???
RE: rear end change
You can swap the gears but you have different carriers. So you need to find out if there are gears for your carrier. I think the easy way is to find out what your gears are now and then as you look for aplications you should see "3.08 and lower carrier. 3.23 and higher carrier" or something to that effect. The posi or limited slip is part of the carrier.
RE: rear end change
The gears just won't mesh right posi or not. Pull the rear cover and the ratio is usually stamped on the pinion gear, if not count the theet on ring & pinion & do the math. Then choose the proper gear set as MadMike said. The posi should fit fine either way.
RE: rear end change
ah, see im terrible at the whole rear end topic so thats why i came to yall. So your saying i can indeed keep the posi if i get the 3.73 gears??? Also, would it be easier to just get that whole rear end???
libertyforall1776
11-10-2007 03:04 PM
