rear diff vent
Old May 26, 2010 | 09:10 PM
bonez's Avatar
Default rear diff vent
i have a rear diff off an 87 Z28,,i changed the fluid and gasket and filled it up. I then noticed i had fluid pouring out of the bottom..when i looked i noticed a small hole which i later discovered was the vent tube hole..Went to the dealer and got a vent. It is a small round plastic tube with a white cap on one end,,
i am assuming the end without the cap is the end that you insert into the hole on the diff..problem is it seems to be a really tight fir,,like you would need to pound it in with a rubber mallet or something..is that suppose to be like that? i took pictures but i can not post them,,,thanx
Old May 27, 2010 | 08:26 PM
microkid's Avatar
March 2011 ROTM
Technical User
fluid pouring out of the bottom? that sounds like a different issue. as for the vent peice, try tapping it in with a hammer. best thing to do is put a small peice of wood over it (if possible) as not to damage it. usually they are hard to press in, and i dont think ive ever seen a screw in one
DDRDiesel
Nov 4, 2012 03:20 PM
AMP3D
Feb 3, 2012 12:28 PM
1stZ28Guy
Oct 3, 2009 08:34 PM
hotrodder83
Mar 31, 2008 02:54 AM
68ssap
Aug 4, 2007 04:14 PM
