Radiator...
Drain coolant.While draining, Remove the four bolts on each side of the fan shroud. Remove the four bolts on the top and if there are a/c hoses on it unbolt that bracket off the shroud. Remove that top half of the shroud. If you have electric fan then you have to unbolt that unit and move it out of the way. Disconnect any cooler lines (transmission and oil if any) be sure not to start the car with these off or fluid will spray. Disconnect upper and lower hose and heater hose from radiator and lift out radiator.
