radiator...
Old Sep 22, 2006 | 09:58 PM
trailerparktrash2009's Avatar
Default radiator...
i just went and bought some head gasket sealer and it says tro drain all thew coolant..how do i do that..also do i drain all my oil out after or before i go though the process of fixing my gasket???
thanxx for the help..
Old Sep 22, 2006 | 11:31 PM
FlufyTiger's Avatar
Default RE: radiator...
Open the radiator drain ****. Should be on the passenger side, if I remember correctly. After that is pretty much empty, pull the lower radiator hose and let everything drain out. But might I ask what you got the head gasket sealer for?
Old Sep 22, 2006 | 11:32 PM
my head gasket is cracked..and i dont want to go pay $800 for a new one..plus no cash right now..
Old Sep 22, 2006 | 11:41 PM
FlufyTiger's Avatar
That works. Best of luck with it. Also, are you supposed to be flushing it, or just draining completely? I hadn't thought about it before, but if you need to flush it first, open that drain **** on the radiator, and put a hose in the radiator fill cap, and just keep it full while the car is running untill the liquid comes out clear, then drain as I described earlier.
Old Sep 22, 2006 | 11:42 PM
i havent read all the directions...all i know is im suppose to flush all the coolant out
Old Sep 22, 2006 | 11:48 PM
FlufyTiger's Avatar
Definitely flush the system first, and you'll probably have to refill the system and run it with the sealer in there for 15 or 20 minutes. I would do an oil change right after, and if it comes out looking milky and brown, I would reccomend changing the oil again after a few days, just to make sure there's no more water left in the crankcase.
Old Sep 23, 2006 | 01:37 PM
ok..thats what i was thinking..thanxx alot for all your help
slim
Apr 15, 2012 09:55 AM
Fuerst94
Aug 29, 2011 12:23 PM
kamaro68
Mar 30, 2008 10:37 PM
Gordon24Camaro
Sep 30, 2007 10:59 AM
JaySan
Nov 26, 2006 03:54 PM
