Question About 350????
i have a 350 in my 89 camaro rs and i would like to know what kind of performance mods i can make to it...rite now im intrested in buying headers and exahust system also i would like to know if i kan add a cold air intake?????
What you need to do is get a bigger carb, a bigger cam, bigger exhaust and maybe a set of heads. Its a ton of work, but you can net an engine that pushes 350 HP and as much in torque....
The single biggest addition you can make is a bigger carb/FI system...then a cam. Those 2 are worth at about 40-60 HP right off the bat. But its not bolt on tuner bull****...it requires knowledge and expertise. You ready to tear this *****' open?
