question
question
if i decide to get headers should i get that with full exaust to the back ? and if so what headers should i get and what exaust should i get dynomax? i want the most hp out of it that i can get andtorqueand what pipe is the best y pipe H pipe or straight back or x pipe
I got a 1990 camaro rs 5.0 v8
RE: question
headers are not something i would want to go cheap with. They look bad and youll wanna replace them before to long. and thats a PITA! Ive got some hookers on mine and they still look great.
as for the exhaust. with a 305, dont go too big, youll run into problems if so. i would think that 3" would be the max size you would want.
RE: question
What about for a 350? I have a pair of Summit Racing Performance Headers. They're flat black, 350 engine block is painted orange. Should look pretty good. Should I keep my flowmasters, or find a new system?
EDIT: Shorty Style, 2.5 inch collectors.
RE: question
Most shorty kits come with the ypipe ie hooker 2055's, slp, hedman, or the edelbrocks. Any aftermarket 3 inch cat back will be fine, its a matter of sound and style preference. i would also look into a high flow cat or replace it with an off road pipe depending on the smog laws in your area. your exhaust will only flow as good as its most restrictive point
RE: question
dont get headers unless u got a motor that makes good horsepower that cant breathe, u put headers on it youll run into overheating problems, ehaust leaks, and youll never want to change ur sparkplugs again just get in the way
RE: question
i say definately get some headers, they made a big difference for my 305, felt alot better power throughout, and they make it easier to get to my spark plus, and havent had an exhaust leak and i just have flow techs! and what do headers have to do with over heating?
RE: question
i put slp shorties on my 87 350 tpi, i definetly have to unbolt the headers to get to my sparkplugs, do u have a stock 305, i put long tubes on another car i had a few years ago and i had to replace 2 starters cuz they fried my starter, i finally wrappedmy headersand put this lil heatshield i bolted to the firewall just so i could keep from replacing starters, and its a waste of money to start on bolt-on parts, id start from the inside of the motor and work my way out,
RE: question
ORIGINAL: hughesis21
