project car opinions
Old Nov 23, 2008 | 04:15 PM
90lxstang's Avatar
Default RE: project car opinions
is there a way to paint interior panels without them looking like crap or having the paint just crack off. the interior of my '84 firebird was originally white and i want to redo it all black/dark gray. the person that had the car before me tried to paint some things already but when you touch them it is either like chalk or it just flakes off. i was just wondering if i'm better off buying black panels or if i can paint the plastic ones. thanks guys!!!! i have already taken most of the interior out of the car and i want to salvage everything i can.
Old Nov 23, 2008 | 11:59 PM
350rs's Avatar
March 2008 ROTM
i used a paint from duplicolor. i took ALL of the panels out and sprayed them. i washed them with hot soapy water. let them dry, and sprayed them. turned out pretty well
Old Nov 24, 2008 | 04:00 PM
90lxstang's Avatar
any tips on getting the old paint off? could i use a paint thinner?
Old Nov 24, 2008 | 04:48 PM
350rs's Avatar
March 2008 ROTM
probably just a brillo pad to get the already flakey stuff off.i suppose you could use thinner. i dont know if that would screw up the plastic itself or not though.
Old Nov 24, 2008 | 08:37 PM
90lxstang's Avatar
yea thats what im afraid of. im gonna try it ona small area first and see what happens. thank you
Old Nov 24, 2008 | 08:55 PM
350rs's Avatar
March 2008 ROTM
try it on the back of one of the panels. none of them are super easy to find OR cheap to replace
Old Dec 2, 2008 | 10:41 PM
barakelium's Avatar
helped my friend do a 6 cyl. camaro w/ a 355 swap. since it was originally a 6 cylinder the suspension on it sucked ***. we did that first because he wasnt driving the car daily. if you intend to drive it while you do it up i would definately build an engine/trans to drop in. if you go w/ automatic- ratchet shifters are always fun. makes it basically a manual w/o a clutch.
Old Dec 3, 2008 | 09:14 AM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
I have that exact same engine you are considering and If I were you I would go with this one instead http://www.jegs.com/p/GM+Performance/752396/10002/-1
by the time you are done with the engine swap you will have spent the same amount as this kit costs. I did my swap from a 305 to the that 350 with the 2nd components package and spent about 3500 dollars by the time it was in. I wish that I had done my research and got the one in the link above instead.
This is the one I might put in, in the next year or two. until I research it more that is. http://www.jegs.com/p/Blueprint+Engines/761293/10002/-1
Old Dec 4, 2008 | 03:35 PM
90lxstang's Avatar
wow that second one is awesome. i might have to go with a 383 instead. i want it to be real good on the street though. that one might be a little too much for me.
Old Dec 4, 2008 | 11:02 PM
  #20
c4maro's Avatar
you prefer auto-tranny on the track!
