Powerful 305 TPIs?
Old Sep 15, 2007 | 09:25 AM
92 Z28's Avatar
Default Powerful 305 TPIs?
Hey Guys,
Have any of yall built up a 305 TPI andruns better then what you expected, or is does the 305 have no hope?
I have a 305 TPI in mine, along with a bunch of mods. This is my first car, so it's fast to me, but I hearthe 305 is adisgrace.
I don't wanna stroke it out, or use bottles. Just Motor, Turbo or SC is alright, but I want to know how much you could get simply on the motor.
Old Sep 15, 2007 | 09:30 AM
84 z .....'s Avatar
Default RE: Powerful 305 TPIs?
looks nice man but u can get around 300 320hp if u spend ur cash wisly, look at the 3rd gen V8 tech page and ull see the light.
[align=left] [/align]
Old Sep 15, 2007 | 09:38 AM
92 Z28's Avatar
300hp all motor no adder?
anyways thanks man
Old Sep 15, 2007 | 10:11 AM
84 z .....'s Avatar
http://www.goingfaster.com/spo/343hp305.html this link was in V8 tech and its what u wanna see
Old Sep 15, 2007 | 11:41 PM
zerokool91's Avatar
you dont wanna stroke a 305. Cuz 305's only have 2 bolt main caps, and you need 4 bolt main caps for that much torque. Dont hold me to this someone correct me if I am wrong. But I think all 305's are 2 bolt main caps.
Z3R0
Old Sep 16, 2007 | 08:20 AM
Jr. Mechanic's Avatar
August 2009 ROTM
ORIGINAL: zerokool91
Z3R0
You are correct
Old Sep 16, 2007 | 01:46 PM
pigchunks's Avatar
your right but wrong lots of people stroke 2 bolt 350's with no issue's the thing with the lo3 305 is that it already has a bigger stroke then the other versions because it shares the same cam as the 350 with smaller pistons which = more compression you can build horsepower based on that alone. the stock lo3 305s problem is restriction exhaust heads and in take can make that motor a totally different motor
Z3R0
Old Sep 16, 2007 | 04:44 PM
August 2009 ROTM
But the thing with 2 bolt mains is that its not good for high rpm's, once that crank starts floating, its not good.
Old Sep 16, 2007 | 08:52 PM
pigchunks's Avatar
thats where quality parts and know how come into play on the stock crank though you are totally right
OurAmericanCars
Oct 10, 2011 02:18 PM
MaVeN
Feb 14, 2011 06:10 PM
RED_CAMARO_V8
82-92 V8 Tech
Nov 21, 2009 08:46 AM
454Corvair
Feb 3, 2007 04:19 PM
