power hatch motor?
go to the junkyard, look for any 1989-1997 Cadillac Sedan Deville, the plastic should be the same, twas stock on all Deville models, also on a side note, the pull down was more common in firebirds and t/a's look for thouse too.
yea cadillac has been using em for years, i have the same unit on my 1995 cadillac Sedan Deville, only difference is the cadillac trunk latches directly to the pull down and the switch is diff, but the motor and houseing should be the same, as well as the plastic gear and bearing inside
