performance heads
Old Aug 5, 2007 | 06:29 PM
gozzy341's Avatar
Default performance heads
Hey, i have an 89 RS 5.0 camaro. Im looking into building into the engine. With upgrades such as, new cam and lifter set, new intake, new heads. I was told if i were to do that i should get a steel braided crank. Is this true? And also if i could get any links of heads to get, it would be appreciated.
Thank you,
Mike
Old Aug 5, 2007 | 07:31 PM
zeus8807's Avatar
Default RE: performance heads
while there are performance heads out there for a 305, may i ask why your putting that kinda money into a 305? i understand if you are looking to keep it a factory motor, but for the money your going to put into building a 305 like you are you could do a 350 or 383 for about the same money.
Old Aug 5, 2007 | 08:11 PM
gozzy341's Avatar
I want to slightly build into the motor i got, untill i can afford a 383 stroker crate
Old Aug 5, 2007 | 08:44 PM
rockin85's Avatar
get an intake, shorty headers, and a carb and mabe a ditributor. that should give you the power you want. you dont want too much power in those 305s, cuz its only a 2 bolt main. too much power will blow apart the crank. the best cheap way for power is to take out the smog pumps, i did, and there was a noticeable differeance.
Old Aug 5, 2007 | 09:39 PM
PedalToMetal's Avatar
How do you do that?
Old Aug 6, 2007 | 08:42 PM
rockin85's Avatar
take out the smog pump?
Old Aug 6, 2007 | 11:51 PM
Yeah, that and AC
Old Aug 7, 2007 | 01:21 AM
gozzy341's Avatar
hahah, i already blocked off the smog pump on mine
Old Aug 7, 2007 | 07:25 AM
blackz87's Avatar
Some people should not be allowed to open the hood of a car.[sm=chairshot.gif]
Old Aug 7, 2007 | 02:27 PM
Well if you never do how can you expect to learn? I'm 18 and this is my first car!
