Oil Pressure connection to block
Old 10-14-2008 | 05:21 PM
Colby90's Avatar
Default Oil Pressure connection to block
The same 89 IROC-Z restoring for my grandson. Going to install manual oil pressure guage. Unsure where the sending unit is. The engine is (?year) a 350 bored to 355. There is a sending unit just to the left(drivers side) of the distributor, is this it? Thank you!
Old 10-14-2008 | 05:33 PM
Default RE: Oil Pressure connection to block
Yes, the port by the distributor is the best place to connect to. The factory plug can be a real pain to get out, but luckily yours has already been removed. If your block is the same vintage as the car, then the original oil sensor location is down near the oil filter, above the boss.
jaeger_bombs
12-20-2013 02:54 PM
KJW468
67-69 V8 Tech
07-22-2013 02:10 AM
a-dusty-camaro
04-24-2009 01:45 AM
max1995
10-31-2008 06:29 AM
