Oil Pressure?
Old 02-19-2009 | 09:21 PM
92ttopRS's Avatar
I would definitely suspect the guage if nothing else has changed. What was the pressure running at before you became concerned?
Old 02-20-2009 | 03:12 PM
bobarian91's Avatar
BackseatBob
Well, when I first got it it stayed between 15-20psi at idle after driving it for as long as it takes to get it down to like 10 now. That's at just under 750rpm, at 1000 rpm it kicks up fast and stays around 40 psi up to about 3000rpm, and then climbs with the revs after that.
Old 02-20-2009 | 04:55 PM
92ttopRS's Avatar
10 is a little bit to think about. How many miles are on the motor? One other thought...I had a mechanical oil press guage in a chevelle and the line got all gunked up causing it to read low. I took it apart at the block sensor and shot some carb cleaner in it...let it drain...cleaned the block fitting and changed oil and filter. Pressure came up a bit at idle...a bit 10-20psi at idle. I always thought it was just a cheap guage (came with car). Autometer 3 guage pack under dash. 350 ran strong and I beat it hard with no problems.
Old 02-22-2009 | 03:14 PM
bobarian91's Avatar
BackseatBob
Yeah, mine are cheap too, the ppl who had em put in didn't care much about the car.
I'm not really sure how many miles this motor has, it came from a junked Camaro...
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
angelus
02-20-2010 01:17 PM
divineal
10-23-2009 12:21 PM
IBSTROKIN
09-09-2009 10:40 PM
Quick Reply: Oil Pressure?
