OIL COOLER?
Old May 8, 2006 | 03:29 AM
hollopointclown's Avatar
Default OIL COOLER?
whad up everyone,
i have an 87 iroc, i have finaly got it back in shape after a crash into a firebird. the large radiator infront of the radiator is the oil cooler or trans cooler right?? i have no radiator or oil cooler in the car. ive lost track of a couple lines. thiers to hard lines coming from under the engine, they were leeking trans fluid till i plugged them.so i would assume they went to the oil cooler, but they are ot bent into the right position an they are way to small. thier are no other hard lines. so if these arnt the trans cooler lines why were they leeking trans fluid??? if they are why dont they fit where they came off from? its confusing the hell outta me any one know how it should be? ive ripped apart an fixed the whole front end an all i need to do it put in the radiator an oil cooler, windshield an hood pins[&:]
KEEP IT JUGGLN
Old May 8, 2006 | 06:48 PM
SickSickSick's Avatar
Default RE: OIL COOLER?
The Radiator Looking Coil In Front Of The Radiator Is The Air Conditioning Coil. The Lines Your Are Refering To Are Transmission Cooler Lines. With Out Them You Will Roast Your Tranny Quick. They Connect To The Radiator On The Passenger Side. You Can Splice Them In With 5/16 Fuel Line And Clamps. Sick
Gorn
Apr 13, 2014 08:15 PM
NorthernCrew454
Jan 28, 2012 12:39 AM
minex
Jul 26, 2011 09:04 AM
sm515
Jul 8, 2009 11:32 AM
thebandit110
Feb 3, 2008 11:48 AM
