NO SPARK!!
Old May 22, 2007 | 09:12 PM
JDzXtreme02's Avatar
Default NO SPARK!!
I am new to the forum and I got a 1989 Iroc and just got done doing the head gaskets and intake gasket and got it all together and i have no spark now. everything is pluged in and cant figure it out. Thanks for any help...
Old May 22, 2007 | 09:19 PM
350rs's Avatar
March 2008 ROTM
Default RE: NO SPARK!!
no spark at all? did you get the distributor in correctly?
Old May 22, 2007 | 09:28 PM
yea i have it in there lose just so i can turn it
Old May 22, 2007 | 09:31 PM
350rs's Avatar
March 2008 ROTM
did you do anything to the ECM? its all computer controlled so if its not getting correct signals, its not gona work right, obviously.
Old May 22, 2007 | 09:33 PM
i will have to check...thanks
Old May 22, 2007 | 09:35 PM
350rs's Avatar
March 2008 ROTM
but other than that, youve got me beat, but there are others on here that will tell you everything you need plus some. so be patient, someone will prolly be able to help as long as you can give the right info
Old May 22, 2007 | 09:42 PM
thanks
Old May 22, 2007 | 10:32 PM
MadMikeZ28's Avatar
You need a motor!
Old May 22, 2007 | 10:35 PM
MadMikeZ28's Avatar
You can take the distributer modules to autozone and have them tested. I don't know what kind of part stores are around you but others should be able to do it. Check the power going to your coil. Check fuses.
Old Jun 2, 2007 | 10:05 PM
Danzig's Avatar
Did this problem ever get resolved?
