No Lights
I jumped in my camaro 91' and pulled the lights switch and no lights. No running lights no headlights. i have brake and turns. what is it? i check the fuses under dash. please help i am selling and need fixed.
91's didnt have running lights.I think you meant the parking lights ? The ignition switch is also connected to the head light switch, maybe there is a bad connection somewhere or quite possible the bulbs are bad.
Dimmer switch. Drop down the column (once the trim under it is removed, it's only 2 nuts.) I think the switch was an $8 dollar part, but it's a SOB to get in. Only 2 little screws but the area is really tight with lots of sharp objects...
i pulled the dash apart and there was no power at the switch. i threw some external power just to test and my interior light and parking lights came on but still no head lights. is there a distribution block under the hood? the only power block i found is the one under the driver dash.
pojo1988
08-27-2017 09:35 PM
bodykits
07-01-2009 09:52 PM
