new alternator and new battery but does not load
Old Feb 17, 2010 | 01:42 PM
davidinoRS's Avatar
Angry new alternator and new battery but does not load
hello to all my e 'a Camaro RS 305 TBI ... and I' happened one evening that marked Voltmeter 10 volt I checked around and it looked .... I put the alternator and replaced the new alternative battery security, but the problem seems the same mattera not recharge from the alternator and the wire to where it does not come out very positive current!. (the new alternator and 'was tested on another camaro identical to mine a friend of mine and it works ) ... and most do not know 'where to look ,.... someone can help me please, ..
thanks., hello everyone!
Old Feb 17, 2010 | 03:35 PM
microkid's Avatar
March 2011 ROTM
Technical User
im having a hard time understanding you. what im getting is the alternator worked on another car, but not on yours? run the car to verify, the alternator should be putting out 13.5-15.5 volts on the batt. terminal on the alternator at 2k rpm. if not, the alternator is bad. if it is within those specs, the wire from the alternator to the battery is probably bad
Old Feb 17, 2010 | 04:29 PM
davidinoRS's Avatar
re-explain, I'm Italian .. I can not write well with the translators, .. then I changed the alternator with a revised and even the battery, the alternator reassembled everything and does not charge the battery I tested with the tester measured by l ' alternative where there is 'very positive wire (near the engine cover) and the tester gave me about 1.5 volts! ... but from the spine over the one with the two-wire current reaches 12, but from ...' 1.5-2 volt alternator goes very low maximum ,.... can 'be qulcosaltro failure or can' be that the alternator and 'bad? thanks
everydayskid
Mar 17, 2013 04:23 PM
Dana
Mar 26, 2011 05:06 PM
WhiteLS1Formula
LS Series Tech
Aug 18, 2009 04:52 PM
9camaro5
Jan 2, 2009 12:06 PM
walsh4nd
Feb 7, 2008 07:14 PM
