need some guidance
need some guidance
so im new here, and have looked around a bit for my answers but havent found them. i was hoping for a little help. i have stumbled across and opportunity to get a 91 camaro, mint body and interior with 53000 original miles on it. the thing is it is having a few engine problems. so here are the problems.
1. 2 fuel injectors are bad and need to be replaced. how hard are they to replace? as of now i dont really know anything about what engine it has so if you could give me any info thatd be awesome. i will know more in a couple of days and will fill in the info as i get it.
2. i have been told there is fuel in the oil. what could be some causes of this?
i do have limited experience working on engines, but mostly the supra im driving now.
last question. 3rd gen supras came out of the factory with undertorqued head bolts, so they blow head gaskets easily if not fixed. are there any problems from the factory with 3rd gen camaros, specifically 91's.
thanks in advanced for any help yall can give me.
RE: need some guidance
The 2 injectors. Is it TPI? TBI? SMFI? V6? V8? ?? The fuel in the oil might be caused by the injectors sticking open and dumping to fuel into the cylinder and then seeping past the rings into the oil.
