need a little help
Old 10-11-2010 | 10:30 PM
ghostrider2/104's Avatar
Default need a little help
i was messing with my after market b&m shifter and to access it a little better i took out the center console and now my car will not start but earlier today it was running and starting fine.
Old 10-11-2010 | 10:38 PM
97blackcamaroRS's Avatar
weird....
Old 10-11-2010 | 10:48 PM
well i bought the car when i was on a deployment so i didnt get a chance to really look at it but the kid i bought it off of had put a viper car alarm in it so i took it out but i just cut the wires off where he spliced into the wiring harnes but the car still will not start and the starter is not energizing but i have power at the starter.
Old 10-11-2010 | 11:59 PM
Caveman305's Avatar
what year is it?
so when you say you have power to the starter, that means all lights and everything works, but when you turn the key nothing happens?
sounds like a Neutral safety switch problem, or if you have a late enough year it might be a vats problem that happen to pop up when you took the console out
Old 10-12-2010 | 12:29 AM
I'm saying neutral safety switch too. Make sure you didn't knock or break the wire off the switch on the shifter.
Old 10-12-2010 | 10:26 AM
yea everthing works lights, windows, interior lights but when i took out the center console since there was a b&m slap shifter installed there were two harnesses that were just laying next to the shifter under the console one had two wires which i think is for the neutral safety switch and another connector that has i believe four wires which i think is for the reverse lights which i do not have. but with the new shifter i have no where to plug those plugs into.
Old 10-12-2010 | 02:52 PM
For the neutral safety switch, you can connect the two wires together, but be careful because you'll be able to start the car while in gear. That, or wire it to an aftermarket momentary switch on the dash. Same goes for the reverse lights, wire to another switch on the dash.
