need help finding cam size.
Old Mar 10, 2009 | 08:53 PM
doug91rs's Avatar
Default need help finding cam size.
im building a 355 out of an old 350 creat motor from gm. the crank n rods r good n im getting new forged aluminum pistons. i have 194 aluminum heads that im porting n polishing for a few extra horses. and i have an edlebrock performer manifold n 650cfm carb. i want to make a good 450hp out of the motor but im not sure what size cam i want to go with. or if you have any other suggestions on what i should do.
Old Mar 10, 2009 | 10:50 PM
Saint_Ali's Avatar
give comp cams a call,they will be able to explain everything to you and help you out with your setup and goals
_night_stalker_
May 13, 2011 05:51 PM
microkid
Dec 20, 2010 08:59 PM
majorpayne41510
Oct 20, 2008 01:36 AM
o2camaross
Mar 24, 2007 12:08 AM
68tubb
Oct 19, 2006 09:55 PM
