MPG
Old Dec 18, 2006 | 07:47 PM
amdmaster1's Avatar
Default MPG
Hey what is everyone getting for mpg... i am only getting 13mpg and all that i have is a 5.0L 350TBI with no smog pump what should i do to get better MPG.
Old Dec 18, 2006 | 08:05 PM
Jmoney's Avatar
Default RE: MPG
You dont have a 5.0L 350....you either have a 5.7 350 or a 5.0 305...cant have both....I have a bone stock 5.7TPI and im at 16mpg or so
Old Dec 18, 2006 | 09:02 PM
74454bb's Avatar
May 2007 ROTM
Default RE: MPG
I may get 6 1/2 mpg, if I'm lucky.
Old Dec 18, 2006 | 09:28 PM
blackz87's Avatar
Default RE: MPG
Go easy with your right foot.[sm=chattypair.gif]
Old Dec 18, 2006 | 09:30 PM
74454bb's Avatar
May 2007 ROTM
Default RE: MPG
it's not the MPG's thats bad,it's the bald tires that seem to be a problem
Old Dec 18, 2006 | 09:58 PM
FlufyTiger's Avatar
Default RE: MPG
Get a real motor for one. What have you done to it already?
Old Dec 19, 2006 | 12:14 AM
74454bb's Avatar
May 2007 ROTM
Default RE: MPG
Ok, I missed the other half of the post. Yoc can get a K&N filter, good plugs, good ignition, Headers and exhaust. But be real, that will make the car a little faster. You have a V8 Camaro, The best way for better MPG is a lighter foot. Anything you do to help the gas will only help your foot need more throtle.
Old Dec 19, 2006 | 02:27 AM
Raven91Z28's Avatar
Default RE: MPG
I still get 13-15 mpg and I've got a dyno'd 400 horse TPI. Seems low mileage for a 305 but yea, if you gotta lead foot, it'll be worse obviously. Also, if the motor is old and running rich or has high miles, it may burn extra stuff like oil and fuel because it is less efficient than it used to be with the wear,carbon/oil build up etc. inside....
Old Dec 19, 2006 | 02:18 PM
amdmaster1's Avatar
Default RE: MPG
yea sorry about that its the 5.0 305 any recomendations on making the MPG better then 13? I have the smog pump removed.
Old Dec 19, 2006 | 03:15 PM
blackz87's Avatar
Default RE: MPG
ORIGINAL: amdmaster1
One suggestion would be to stop removing[sm=chattypair.gif] parts that you don't know what there functions are.
