motor wont spark
Old Sep 18, 2010 | 09:53 PM
bryan0609's Avatar
Default motor wont spark
i just rebuilt my motor and got it put in wired up and went to start it to make the final adjustments on the rockers but went to fire it and there was nothing tested the coil and it was bad so i replaced it but now still no fire i checked the coil and im getting power in and out of the coils but nothing out of the spark plug wire from the coil to the distributor i am so confused on what it could be now can anybody help me
thanks
Old Sep 19, 2010 | 08:33 AM
Y2K's Avatar
Y2K
Are you sure you put the rotor back in?
Wish I could say I've never done that lol.
Good luck with it
Old Sep 19, 2010 | 12:52 PM
bryan0609's Avatar
yes i have the rotor in the cap i have not taken it apart since my complete msd iginition upgrade along with a full tune up about 50 miles before i bent the push rod and spun a bearing
Old Sep 20, 2010 | 08:11 PM
bryan0609's Avatar
so no im getting spark my ingintion module was bad replaced it but now that im getting spark it still wont fire, im getting ingition is a few cylinders but not enough to start it could my timing be off or what im lost now so please any help would be greatly appreciated
thanks
Old Sep 20, 2010 | 09:11 PM
black89rs's Avatar
check your plugs they could be gas fouled. you are getting spark at the spark plug end of the wires right??
Old Sep 20, 2010 | 09:12 PM
black89rs's Avatar
oh by the way ignition is how u spell it
Old Sep 20, 2010 | 09:14 PM
black89rs's Avatar
Exclamation
Good luck with it
thats not as bad as doing it twice on the same car. too much alcohol that night.....lol
Old Sep 20, 2010 | 09:21 PM
Y2K's Avatar
Y2K
Old Sep 20, 2010 | 09:23 PM
black89rs's Avatar
[QUOTE=Y2K;457364]Did you follow the correct procedure for installing the dizzy?
never heard it called a dizzy before.....but in a retarded way it makes sennse...lol
Taintedlogic
Oct 16, 2013 04:11 AM
PatKeenan
Sep 27, 2012 04:37 PM
bradspaugh
70-81 V8 Tech
Dec 18, 2009 08:08 PM
Hotrod688
Mar 12, 2009 08:10 AM
1971RS
Jan 4, 2009 11:06 PM
