Mice In My Cluster
Old Sep 7, 2011 | 07:06 PM
beckler's Avatar
Default Mice In My Cluster
While moving, I hear something squeaking inside my instrument cluster. If I accelerate, the frequency of the squeaking increases with speed. Could this be the cable that's responsibly for sending speed back to the speedometer? That's my guess. Anyone else have this issue? What'd you do to fix it?
Old Sep 7, 2011 | 07:11 PM
gfrench's Avatar
yes, it is probably the speedo cable.
They are only $6
Old Sep 7, 2011 | 07:18 PM
beckler's Avatar
Thanks for the reply. Where does the cable track back to? How much of a pain is it to swap out?
Old Sep 12, 2011 | 04:21 PM
ColSheppard's Avatar
not much and it goes back to the transmission on the drivers side at the back
Old Sep 12, 2011 | 05:44 PM
What year is your car? 1990 and newer has an electric speedo, not cable driven.
Old Sep 14, 2011 | 10:06 AM
beckler's Avatar
Sorry, it's an 88. What if I just give it alittle WD40 or some white lithium grease? No good? Or does it have to be replaced all together?
Old Sep 14, 2011 | 01:26 PM
Depends on what's squeaking, the cable or speedo. For the cable, clean it well and use a graphite based speedo cable lube. Regular oil or grease can gum up the cable and make the needle jumpy.
Old Sep 15, 2011 | 11:12 AM
beckler's Avatar
I'm trying to gain access to this damn thing and i just spent 20 minutes taking the cluster apart... I cannot get the speedo off. It doesn't pull out like the rest of them. I noticed the two small flat blade screws and I took them off, but I cant get the needle off. I tried yanking it and it isn't coming off. So before I broke something, I figured I'd just run it by on here. What do I need to do to gain access to the speedo cable?
Old Sep 15, 2011 | 01:02 PM
beckler's Avatar
Okay, update. I got the Speedometer off. (Just a tug and the needle pops off). Now, I'm trying to figure out how to get the big plastic bezel out. I found the two hidden nut-shaped clips closer to the bottom, but there's something that needs to be disconnected behind where the speedometer sits. It's the speedometer cable housing thing that I cant figure out how to disconnect from the white bezel thing. Anyone know what I'm talking about here?
Old Sep 15, 2011 | 02:41 PM
Are you just trying to lube up the speedo cable? It would be a lot easier to disconnect the housing from the trans and pull the cable out from down there. I don't get why you're trying to take the speedo out of the cluster?
