M.A.F. & TPS sensors
Old Dec 11, 2011 | 04:29 PM
Kayce MissChevy SuperSport's Avatar
Default M.A.F. & TPS sensors
So, i got a 88 Iroc 305 tpi that i took to the shop thinkin it was my fuel pump, found out it was my m.a.f. sensor for sure and could be my tps sensor as well, im pretty hands on and i just want to check and see if these are simple things i can do myself... i wont need a diagnostic tool or anything to reset codes will i? also, is there any m.a.f. sensors that i should look at?
Old Dec 11, 2011 | 05:25 PM
iLL95's Avatar
I Like to Party
Super Member
There is a way to re-adjust the new TPS, back probe the ground and signal wires and adjust it till u get a reading of about .55 volts then tighten it down. A new MAF shouldn't need any degree of re-adjustment
Old Dec 11, 2011 | 07:07 PM
Thanx!!
dmoneey05
Feb 26, 2012 11:03 AM
Kendagenius
Jun 20, 2010 06:02 PM
RoyBean
82-92 V8 Tech
Jun 1, 2010 05:46 AM
bidicamaro
Apr 24, 2008 12:10 PM
Lucas
Mar 5, 2008 06:48 PM
