LT1 swap on a 91 RS
Old 10-15-2006 | 12:13 AM
motor tec's Avatar
Default LT1 swap on a 91 RS
Ok, so i have a 91 RS with a TBI 305. An if you read my other post you will see that i had a horibale experince racing a blazer last night. Anyways I've always liked how the intake manifolds look on the LT1's and seein on how it's a 350 an all i know ill get some power gain with further potential than a 305. so i was wondering if ya'll knew what it would actually take to drop this in my car. right now it's a auto matic but thinking bout converting it during the swap. also keep in mine i have acess to a shop with a host, crain, tool, and machine shop, an most parts at cost, so what would it take to do that. also i have a 350 on the floor so i would use that block with LT1 heads and manifold.
Old 10-15-2006 | 10:46 PM
uncle bill's Avatar
Default RE: LT1 swap on a 91 RS
See if You can find a donor car ( wrecked ) and get the whole package ( engine, trans , computer, fuel system. etc. ) and swap everything out. It'd be cheaper to buy a wrecked car and take it out, a wrecking yard would kill Your wallet.
Old 10-16-2006 | 12:16 AM
The LT1 heads and manifold won't work on a regular 350, water passage problems. You also need the LT1 block. It would easier to put a good set of heads, cam, and manifold on the 350, or get a donor car as uncle bill stated.
Old 10-18-2006 | 02:38 AM
lukedespain's Avatar
I have the exact same car as the guy originally positng here. I have no ability to do the work myself, but I am wondering, if I was to purchase the doner car or the parts, what would it cost me to have the engine-tranny combo swapped? Would it make a difference between LS1 or LT1? I used to have a 96 WS6 Trans Am which was fast enough but my TBI 305 just never cut it. It was my first car and has been sitting for 5+ years now. Still looks good but it needs some major mechanical work. Thanks for the help.
Old 10-18-2006 | 12:27 PM
Deezil13's Avatar
I would personally go with the LS1...thats what I am thinking for my 2.8 swap but its that or a 350. I know there is a lot you can do to an LS1. I know someone who owns a trans am LS1 with a rear mounted turbo that thing flies....600HP at the rear wheels
Old 10-18-2006 | 12:38 PM
shnormo's Avatar
LS1 was built for power and abuse. It is a 6 bolt main!
http://en.wikipedia.org/wiki/GM_LS_engine
Old 10-18-2006 | 04:30 PM
So any idea on the cost of install?
Old 10-18-2006 | 07:01 PM
IMO you should take the 350 you have on the floor, with a good set of heads, cam and manifolds it cam make as much power as the LT1 or LS1, and save yourself a lot of work and money. Small blocks used in NASCAR racing produce 700 to 800 HP with a 4 bbl carb, so the potential is there.
Old 10-20-2006 | 01:27 AM
motor tec's Avatar
well what im doin now is this. I have a 350 out of a 93 chevy 2500. i pulled the head and i'm havin the milled .20 then im changin all the gaskets an seal an maybe changin the came..dont know for sure. boltin it all back up an putin her back in.
3800_seriesII
08-14-2012 07:24 AM
9434V6
09-08-2011 11:51 AM
xXChipXx
08-01-2010 10:39 PM
miclo88
10-15-2009 07:38 PM
85z285.0
06-02-2007 03:19 PM
Quick Reply: LT1 swap on a 91 RS
