LT1 or LS1
Old Jan 2, 2006 | 02:37 PM
freekstylejimmy's Avatar
Default LT1 or LS1
Im new here. But this is my 2nd 3rd gen. ive owned. Its a 91 RS 3.1. I bought it off a friend who didnt have time to put in to it. I think I stole it for $500.00 It has 250,00 miles on it. 1 owner. The body is mint, the interior could have a little help. Brand new tires, brakes, wires, plugs, cap and rotor. I want to drop a new engine into to it. I dont know if i should go with a LS1 or an LT1. Maybe you all can help me with that. Or if you think I should go with something else. Maybe get a 350 turbo tranny? But does anyone know if ill have to shorten or add to drive shaft? Any help would be great thanks guys. Glad to be part of this forum
Old Jan 2, 2006 | 05:59 PM
waytofast's Avatar
Default RE: LT1 or LS1
i think it depends on what kind of transmission u get if u will to replace the drive shaft...and u will defently have to get a new transmission if u plan on put a lt1 or ls1 in your car... sounds sweet... wish i had the cash flow to do something like that 2 my car
Old Jan 3, 2006 | 02:32 PM
Does this sound like a really good deal? or do you think that i could piece together a stronger engine for around the same price if i do a little shopping around. Im looking at somewhere around $7500.00 as a budget. But i was hoping to get a little more than just the engine done for that price.
Complete Ignition - 5 Wire Hook-up
Coil packs, wires and plugs
Delphi ECM with TurnKey calibration
Custom marine grade engine wiring harness
Uses all OEM connectors
Electric fan controls
Complete Accessories
Alternator and water pump
Serpentine belt system - Brackets and tensioners
Complete AN Fitted Fuel System
AN fitted fuel rails
EFI fuel pump kit
Pre-filter
Fuel pressure regulator
-6 & -8 Fuel line fittings with o-rings & crush washers
Complete Detail Package
Engine oil and filter
K&N air filter
Hardware kit
Motor mount bolts
Oil temp. sending unit port
Water temp. sending unit port
Vortec engine covers
Installation guide
Street Package Includes
Flywheel or Flexplate
Starter
Exhaust manifold
$6,800.00
390 H.P LS1/LS6
420 Ft. Lbs Torque
Type: 5.7L V-8 Small Block
Displacement: 5665 cc (346 ci)
Compression ratio: 10.1:1
Bore x stroke: 3.90" x 3.62"
Fuel system: sequential fuel injection
Rev Limit: 6000 rpm
Block: cast aluminum
Cylinder head: cast aluminum
Intake manifold: composite
Connecting rods: forged powder metal
Old Jan 3, 2006 | 04:27 PM
Lee Willis's Avatar
An LS! will shread your transmission in no time. Put a new trans in if you plan to use an LS1. You will probably have a host of problems fitting accesories and such to it, too, but it will fit and run with that kit you listed. You make need/find it hard to find a new bellhousing that adapts.
An LT1 will also give it fits but not as much and will fit a lot easier.
