Look at this rocker footprint. Longer pushrods?
Old Dec 31, 2009 | 10:15 PM
ScottD's Avatar
Interesting, I measured that on dry lifters....Ill try again with two fully soaked lifters and see if it looks any different.
Im tempted to just order the +.100 variants and be done with it!
Old Dec 31, 2009 | 10:41 PM
i got my lifters and rockers from the same place and they loaned me the right solid lifter to use. it will not make a difference to pump them up the lifter needs oil pressure to be in working order so for it to work the motor would need to be running. stop by the local parts store to see if they sell or loan a lifter.
Old Jan 1, 2010 | 12:19 PM
Jr. Mechanic's Avatar
August 2009 ROTM
I would soak the lifters and pump the air out of them. That DOES make a difference over dry lifters. Check it then. If there's no difference, I would go with some rods that are .100" longer.
Old Jan 1, 2010 | 05:34 PM
ScottD's Avatar
I let the lifters soak overnight, I tried again today. The footprint was a little neater but they still appear short. Im going to buy the checking tool soon. No sense in guessing....its not like Ill be driving anytime soon. As cheap as I am, id rather wait the extra time and spend the extra 20 bucks...even though I know Im gonna need .10 over......
Old Jan 1, 2010 | 05:46 PM
August 2009 ROTM
Good call. Hot rodders have been slapping together valve trains for years and years. While guessing works okay some of the time, it's not the correct way to do it.
Old Jan 1, 2010 | 07:07 PM
microkid's Avatar
March 2011 ROTM
Technical User
now do you see why it costs so much money and time to build a high performance engine? im not that old, but i have built a few in my days. usually when it comes to rebuilding a 350 from a fresh block up, it ends up being cheaper in the long run to just buy a crate engine. i was going to build one for myself, but after the costs of everything involved, the time, and all the small stuff that needs to be purchased (like a push rod length checker), it wound up being cheaper to buy a crate engine
djsquare1
Apr 28, 2013 01:51 PM
Shalamara
Aug 15, 2012 07:25 AM
Shalamara
70-81 V8 Tech
Feb 16, 2012 08:57 PM
brenkate
Oct 22, 2007 12:28 PM
gotalcoholmanup
May 24, 2006 11:15 PM
