Left fender
How do i replace the left fender on my 87 z28? I have taken the hood off and the screws around it. I was looking at the replacement fender i have and it has screws in the front, but i dont know how to get them.
[IMG]local://upfiles/3893/B838421DE9414E399B6024A6702FEDFC.jpg[/IMG]
The screws in the front can be gotten to through some holes inside the engine compartment and above the plastic shield under the car.
Also remove the Z28 emblem from the rocker. It is plastic studs in barrel clips so just pry gently on each end. There will be screws under it. Open the dorr and remove the screws from the rocker and it comes up in the back on the quarter. Taking the whole rocker off is easier than working around it.
There are also bolts on the bottom of the fender where the rocker was.
unbolt the plastic wheel well linner.
Back to the front of the fender on the underside there is a brace that need unbolting.
Unbolt the hood hinge. hopefuly you marked the hood where it was so it makes it easier to put back on. And unbolt the frest of the fender.
I think I got everything.
