led turn signals?
Old Oct 22, 2010 | 07:38 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default led turn signals?
who here has them? i know someone does and it didnt make it blink insanely fast. anyone else here have them? what brand did you use?
Old Oct 23, 2010 | 09:19 PM
yankeeboy's Avatar
This is the post you saw them mentioned: https://camaroforums.com/forum/82-92-general-10/turn-signal-problem-53809/
I forget which brand I got, but I got them in Autozone and they worked perfectly fine.
Old Oct 24, 2010 | 07:07 PM
microkid's Avatar
March 2011 ROTM
Technical User
did you run them in both the front and rear, or just the front? got any pics?
Old Oct 24, 2010 | 09:41 PM
yankeeboy's Avatar
Im actually on vacation for the next week and a half so I wont be able to take any pics till then, sorry. I installed the leds in the front and the rear, and didnt have any issues with the flash pattern. I never actually tested the turn signal with leds in the front and regular bulbs in the back so I've no idea if there will be a flash issue with that setup.
Old Oct 24, 2010 | 10:41 PM
yankeeboy's Avatar
If you wanted to do a custom setup, you could try this: http://www.youtube.com/watch?v=a-CjBO9GVUA
Looks cool, but the led replacement bulbs do a great job with a lot less effort
Old Oct 25, 2010 | 07:33 PM
microkid's Avatar
March 2011 ROTM
Technical User
yea, i dont have that much time on my hands to do that sort of work
Old Oct 25, 2010 | 08:35 PM
yankeeboy's Avatar
Yeah there looks to be a lot in it. I'll have a look online for the leds i installed and il post the link here for you
Old Oct 25, 2010 | 08:41 PM
microkid's Avatar
March 2011 ROTM
Technical User
if i go about getting them, i think ill get a full set from www.superbrightleds.com they have all sorts of configurations of bulbs that allow different angles of light to use the factory reflector, etc. etc. but they arent cheap
Old Oct 26, 2010 | 05:38 AM
FSTKMARO's Avatar
LED lights are awesome but can trigger a burnt bulb condition or when used as turn signals they can result in fast blinking of the lights. The solution to this is a high power resistor across the leads of the bulb that will simulate the old filament. Another solution in the case of turn signals is to replace the flasher. Many LED replacement light stores sell the flashers but many require re-wiring since they seldom match the carrier on our cars. These replacement flashes work with either filament or LED lights and many are solid state hence they make no clicking noise.
I had a motorcycle once that I went with LED lights for it. I had to use the resistors until I found the correct flasher. The fast blinking is annoying lol.
Anyways, it is doable and even autozone and advanceauto parts carry the replacement 1156 and 1157 type bulbs so they are readily available.
good luck
jim
Old Oct 27, 2010 | 10:06 AM
Caveman305's Avatar
