insulation in trunk
Old Jan 8, 2011 | 07:46 PM
muaymendez1's Avatar
Default insulation in trunk
I just looked for my jack and spare today and noticed that there is nothing in the well. its metal with a drai hole. i bet that allows cold and heat in to the car since there is no seperation between trunk and pass area.
Does any know if there should be something there or is this the way it is.
Old Jan 8, 2011 | 08:10 PM
blackz87's Avatar
What you saw in there is what came from the Factory. Insulation in cars not much.
Old Jan 9, 2011 | 02:38 AM
carguy68ssrs's Avatar
There should be a plug in the drain hole and with the panels on you are not going to get much heat loss or gain. Not like you are right next to it anyways.
Old Jan 9, 2011 | 01:09 PM
junior.davilar's Avatar
carguy68ssrs got it right. There should be some insulation on the panels tho. If not you can always add some.
Old Jan 10, 2011 | 08:05 PM
microkid's Avatar
March 2011 ROTM
Technical User
thats why older cars weigh less. no needless insulation. theyre may have been some on the plastic panel at one point. if you want to add some, go right ahead, but theres not really a good point to
Old Jan 15, 2011 | 04:18 PM
Davidearlcox's Avatar
There should have been a spare tire, jack and lugwrench inside.
darrellv
Jan 5, 2013 10:26 AM
Chevynutz
Jul 27, 2012 09:13 AM
CZimmer
Jun 3, 2012 01:25 AM
danimaldds
Jun 19, 2008 05:32 PM
Interceptor1
Aug 2, 2007 07:54 PM
