inline fuses?
There is an inline fuse for the fuel pump on the passenger side fender. There's a wire that runs along there, and a little black piece of plastic. That is, if you stop using caps. If you wanna keep the caps up, then I'll tell you that you're gonna have to cut into the middle of the firewall, right behind the distributor to get to it. Lose the caps key, please.
