ignition problem (help)
Old Dec 24, 2004 | 03:24 PM
adam89's Avatar
Default ignition problem (help)
i have an 89 RS with a 2.8L motor. when i try to start the car nothing happens. sometimes i keep trying and maybe like 1 out of 20 tries it will start. all the lights come on and the car will start with a remote starter. i have the security key but other keys do not work. i was thinking maybe the security system went bad after i changed the ignition switch no no avail. any ideas of what to test?
Old Jan 16, 2005 | 05:58 PM
spdshftr's Avatar
Default RE: ignition problem (help)
what i would first is check fire, spark or fuel. then check from there i would check the distributor module, or the computer.
Old Mar 21, 2005 | 10:50 PM
HotRod53's Avatar
Adam, give me some more info..when you say doesn't start do you mean everything works but not even a click? See my recent posting to user name "Error_505", sounds like the same problem. Read my post and respond if you need to, we have an '89 and based on your short description, I have had the exact problem in the past. Remember if your security system works correctly, only the correct key with the resistor in it will start the car. A remote starter system bypasses the PassKey system, otherwise the key would have to be left in it to start it.
novaboy87
Oct 4, 2010 04:21 PM
Gordo GT
Jan 30, 2010 02:46 PM
Exterminex
Aug 3, 2009 05:18 PM
parchisi
Jul 2, 2009 09:09 AM
benjamindcox
Apr 7, 2009 04:52 PM
