Ignition issue
ok this iroc was completely rewire using all different colored wires, i took the alt off and coil off for some other issues i was taking care of, went to re-install both and am just shocked thati didnt label them before i removed them. so i get no spark , now i have to wires with connectors for the dist 2 of them both red, they both run into the firewall, its a mallory ign by the way, i cant figure which one goes on which the side or bat side. and with the alternator all the wires that have a nut i can figure out but the 2 small wires on the bottom what use the recep type plug i cant figure which one goes to which, i believe they have some letters on there. i plan on getting a new harness but for right now i cant afford. it was running b4 i removed them both. just a little help on where which wire should go, also is there a fuse for the ign that i might have blown. its a 87 305 carb
