Idling and Charging issues.
Old Mar 1, 2011 | 01:21 PM
McGnrAcDcfan227's Avatar
Default Idling and Charging issues.
Hey Guys,
So the 305 finally got dusted off yesterday, and I'd like to get her ready for the summer, but before she'll be drivable, I've got to work out a couple kinks.
1. When the Engine is at Idle, and I shift into Drive, the Rpms drop way down and it stalls out. Due to advice from my grandfather, I've been chasing the mythical timing bug, but this happens no matter where I set it. Does the T/v cable need adjusting?
2. Something in the electrical system is drawing current, even when the key is off, to th point where if the battery is fully charged, and the car sits overnight, it wont have enough power to start in the morning.
3. Is there anyway to adjust the tach? Because mine reads 2200 at idle but the motor sounds like its alot lower.
Old Mar 1, 2011 | 01:44 PM
I've had a 91, so can relate to part of what you're asking.
1. The TV cable may need adjusting, but it has nothing to do with the engine killing. Check it if you haven't yet, as proper adjustment is key to good shifts and transmission longevity.
2. You're going to have to hunt down your gremlin. First, I would have the battery load tested to make sure it doesn't have a bad cell. Then pull one fuse at a time for your accessories and see if the battery survives the night with one of them out. Does your car have an aftermarket alarm? Those can sometimes go haywire and drain the battery.
3. Welcome to the 3rd gen Camaro, more factory tachs go bad like that than not. Mine read double, but it did keep my math skills well polished.
Old Mar 1, 2011 | 03:28 PM
djs383's Avatar
I would agree with 69, but I'll go a step further.
1. TV cable will have nothing to do with idle. What year is your car? carb, FI?
2. The faster way to check for amp draw is to 1st, load test the battery. Then once you determine the battery is good take a multimeter and put it to DC amps and disconnect the positive cable from the battery, remove one fuse at a time, then connect the circuit via the multi-meter, this will identify what circuit is drawing amps. Most likely it will be a relay....
3. I agree with 69 on his tach post.....
Old Mar 1, 2011 | 04:20 PM
Thanks for the help guys, I'll defiantly have to go bug hunting tomorrow, the car is a 92 with a 700r4 and tbi, any idea what the stalling might be caused by?
Old Mar 1, 2011 | 06:48 PM
Does it stall out if you put it in reverse and/or a low gear (1st). That will determine whether or not it's a torque converter locking up when it shouldn't be issue or not.
Old Mar 1, 2011 | 06:52 PM
I'll go a step further with your further step...in the morning, before you start the engine, feel the alternator to see if it's warm, and put an ear to it to listen for any whiny noise. Make sure the doors are closed and key off to so you aren't causing any current draw. Alternators have been known to go bad (short) and cause a battery drain.
Old Mar 1, 2011 | 06:58 PM
microkid's Avatar
March 2011 ROTM
Technical User
does the idle change when cold or hot, a/c on or off? sounds more like a bad iac valve
Bepps95_3.4
Jan 3, 2012 11:01 PM
husker_camaro95
Jun 29, 2010 11:55 PM
evilbeef54
Jun 15, 2009 12:47 AM
sidewayz28
Dec 11, 2008 11:08 PM
Spike
82-92 V8 Tech
Jul 17, 2007 08:28 PM
