Idle Problems...Help!!!
Old Jun 15, 2010 | 07:58 PM
jcase350's Avatar
Default Idle Problems...Help!!!
I have a 90 camaro Iroc w/ 350. The idle is surging up and down pretty bad and it likes to die and when I push on the gas the RPMs drop like it wants to die but as soon as they drop they come right back up and go. Is there a way to tell if the IAC motor is good or bad? Also, my Inflatable Restraint light is coming on. Would that mess with the car's performance? Doesn't do it all the time, sometimes it runs fine. Even at higher RPMs you can tell it's still surging a little. I just got done replacing the EGR Valve, Cap and rotor, TPS Sensor, coolant temp sensor, plug wires, plugs, fuel filter, and the ignition coil. Also, I just checked to voltage on the TPS sensor and it's reading .75 volts with the ignition on without it running....doesn't have anwhere on it to adjust that I can tell. Is that to high or should it be set right at .54 volts?? Help!!
Old Jun 15, 2010 | 08:26 PM
microkid's Avatar
March 2011 ROTM
Technical User
Old Jun 17, 2010 | 05:07 PM
jcase350's Avatar
Yep...that's it. I just verified that's it not the IAC valve or a vacuum leak....
Old Jun 17, 2010 | 07:41 PM
microkid's Avatar
March 2011 ROTM
Technical User
how did you check to make sure it wasnt an vacuum leak?
Old Jul 18, 2010 | 05:22 PM
jcase350's Avatar
Finally fixed...I changed out the injectors and a vacuum hose. Right underneath the plenum is the EGR valve. Right on top of the EGR valve is a vacuum hose that connects to it. There is a little bit on the under side of the plenum that was pinching off the hose...that's why I couldn't find a leak. Thought u guys might wanna know. Now she's running like she should!! Thanks guys
B_Dubya
Oct 21, 2014 11:33 PM
BrianFol
Feb 5, 2013 06:39 PM
delta2ul
Dec 11, 2009 04:13 AM
Black91Camaro
Sep 8, 2009 03:14 PM
Sodamhot
Oct 27, 2007 11:56 AM
