i need help!!! bad!!!
Old Apr 15, 2007 | 03:31 PM
justnice980's Avatar
Default i need help!!! bad!!!
i'm kinda a novice at working cars. i was wondering is someone could help me. i need the firing order for a 1987camaro sport coupe berlinetta6 cylinder 2.8 multiport. i need to know the engine order and the distributer order. i think i got it wrong. if someone could please help me i would really appreciate it. HELP!!!
Old Apr 15, 2007 | 03:35 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: i need help!!! bad!!!
What year?
Old Apr 15, 2007 | 03:37 PM
1987
Old Apr 15, 2007 | 03:55 PM
also, i replace the ignition module and i think i may have crossed the positive and negative wires but i can't tell. they are green and yellow and i'm not sure which one is which.
Old Apr 15, 2007 | 05:14 PM
MadMikeZ28's Avatar
1-2-3-4-5-6
Same for all years. 2.8, 3.1
AND
If I remember correct #1 cylinder is on the right. Best thing is look at the heads. Which one is the most forward? That would be #1 side and on GM the #1 side is 1-3-5. The cyliders on the other side are 2-4-6.
The distributer turns clockwise and should be marked with a "1" on the cap.
Old Apr 15, 2007 | 06:45 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Yup, thats what I got too.
Old Apr 15, 2007 | 06:50 PM
can you tell me anything about the ignition module just under the distributor cap? the positive and negative terminals had green and yellow wires attached to them but i'm not sure which is positive or negative green or yellow?
Old Apr 15, 2007 | 06:51 PM
