I need help
Old Sep 24, 2006 | 10:03 AM
elindecker's Avatar
Default I need help
My name is Eric. Im in the Army and stationed in Germany i just bought a 92' camaro rs for a project car. There are 3 sensors or relays location under the hood at very top driver side on the firewall. Can someone please tell me what the are and where i can order them from? One of them is a square and thin and the others are zip-tied to the brcket right there, I know they slide on to that bracket.
Thank You
Old Sep 24, 2006 | 11:29 AM
SickSickSick's Avatar
Default RE: I need help
hello eric. the three relays you are referring to are fuel pump, a/c compressor, and coolant fan. i'm not really knowledgable on ordering stock parts but you could probably get them from ebay or maybe even summit racing. there addy is www.summitracing.com . someone else might can help you in ordering. good luck. Sick
Old Sep 24, 2006 | 12:41 PM
blackz87's Avatar
This is a picture from another Form that shows the location of the Sensors in your question.
Any Auto parts store should have these parts if you give the name of the part & car info.
[IMG]local://upfiles/2696/E0DD21411EF146939F30ABE200438ECC.jpg[/IMG]
Above is for a TPI engine.
Old Sep 24, 2006 | 02:14 PM
an over looked question is ... what engine do you have? the info i gave you is for a 2.8 liter. heres a diagram. http://cleanandsober.741.com/Diagrams/Relays2.jpg ... Sick
Old Sep 24, 2006 | 03:57 PM
FlufyTiger's Avatar
Advance auto parts sells them for about $10 a piece, and they used to, I don't know if they still do, carry a lifetime warranty on them. I went through probably 7 or 8 of those relays untill I could find a new section of wiring harness to replace the burnt connector. http://www.partsamerica.com/ProductD...pe=600&ptset=A Yeah, only a 1 year warranty, now, but still not bad.
