I just got a '91 RS
Old Mar 25, 2007 | 03:03 AM
jourtni's Avatar
Default I just got a '91 RS
And I am planning on fixing it up to the max..... I am anticipating an engine swap after i get out of college, and totally tearing everything out and redoing it... .but for now I was looking for some fairly cost efficent ways to give it a little boost..... It is for the most part bone stock
It has a 305
and a K&N filter...
I am getting my cat cut off and having 3 inch pipe run to the back to a flow master
other than that it is bone stock i think. anyone have some suggestions? or Ideas? I plan on slapping the biggest engine i can possibly fit in there once i get out of college.... Suggestions on that would be appriciated as well. Thanks
Old Mar 25, 2007 | 03:08 AM
92camaroRS's Avatar
Default RE: I just got a '91 RS
Get some headers and a y-pipe. If its a TPI get a 58 mm trottle body. Also maybe some gears, 3.73s.
Old Mar 25, 2007 | 12:50 PM
jourtni's Avatar
ORIGINAL: 92camaroRS
it isnt tpi but is there any certain headers you would recomend?
Old Mar 25, 2007 | 01:31 PM
blackz87's Avatar
Why are you cutting the cat out?? You are not going to gain anything with the LO3 TBI and its stock 170 HP and it will not pass a Emission check. Also if you say your State dose not requireE- Check , well it is comming to your area.
Old Mar 25, 2007 | 02:30 PM
coprunr's Avatar
since your wanting to do an engine swap later , don't do anything you can't use on the other engine. i'm guessing you want to do a 350 swap (hopfully with TPI not TBI) . so focus on things like headers , y-pipe , exhaust, a stall converter ,a shift kit, gears , limited slip , aluminum drive shaft , and other things that will get the most out of the current engine and will complement the engine youplan on swapping in. the mods listed above won't give you alot more hp, but will make it easier for the hp you have to get to the ground, and you will notice quite a gain in performance even with the 170HP 305.
