i have a camaro and a Q
Old Oct 19, 2005 | 09:08 PM
devile's Avatar
Default i have a camaro and a Q
I have a 1985 witha 2.8 and i want to convert it to a 350 (i read the sticky) i know hwo to do the motor swap just wondering what else i have to change... i went and got an IROC body kit for it, and like, where should i get the manual tranny for it, out of one with a 305 or 350 or does it matter... and what camaro's came with Posi rear ends, and if not a specific model, then how do i tell if it's posi... and if i get a differnt tranny and rear end, are all the drivshafts the same???? Thanks for all your help
Oh and the computer... when i do my conversion (motor) i know i'll need a computer from one that had the same motor (or just a v8 period?) but will i need all the wiring too???
Old Oct 20, 2005 | 07:32 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: i have a camaro and a Q
you will need the computer for the motor (305 or 350 respectively)
good luck finding a manual out of a 350 IROC
Posi is hard to tell unless you look at the ID codes on the rears
Wiring will need to be changed because either
1. you are switching to Tuned Port
2. you are switching to carb AND
YOU WILL NEED TO CHANGE THE FUEL PUMP AND LINES
and motor mounts
Old Oct 20, 2005 | 09:04 PM
r0nin89's Avatar
Ughhh you cant get a 350's manual tranny. CHevy never bothered to put them in the cars with a 350 cause they couldnt handle the power and were too lazy to put in a better tranny.
Old Oct 20, 2005 | 09:14 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
not true. Canadians had them. i saw one in camaro performer magazine a few months ago. very rare
Old Oct 21, 2005 | 02:34 AM
devile's Avatar
Well, i like in Canada and think imight know where to get the tranny... so i need a tranny out of a 350 if i want one that'll hold up to it...
and for the wiring... Becuase it's tuned port i need new wiring... Ok... so if i go tuned port, would it be easier and chaper to set up a stand alone, or to go with stock
and it says in the techy that all you need is a computer, doesn't say anything bout the wiring
Old Oct 21, 2005 | 06:50 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
well you would need the wiring for the TPI system, and the injectors as well as a new fuel pump
Old Oct 21, 2005 | 11:05 PM
devile's Avatar
but if i just put in a regualr 350 that i built, then waht
Old Oct 22, 2005 | 02:56 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
depends on the top end of the original motor, was it MPFI or Carb? and depends on top end of the 350. you probably will have to up the fuel lines to feed a bigger carb, and if your switching from MPFI to carb you will have to switch the pump i think to avoid over feeding the carb with a high pressure system
Old Oct 22, 2005 | 03:11 PM
Agreed. A fuel injection pump puts out way too much pressure for carburators.
Old Oct 23, 2005 | 03:15 AM
devile's Avatar
Well the 2.8 was a MPFI, so if i build a MPFI 350, than i would have to upgrade the fuel lines... does this sound correct... but could i still use the original wiring? (for the computer) or would i need a computer out of a car with a MPFI 305 or 350?
