I dissconnected the timing connector......
Old Mar 25, 2007 | 09:21 PM
BlackIceZ28's Avatar
Default I dissconnected the timing connector......
On the last post i was having a problem with the timing. I found out that I may have bad spark plug wires and need to change the spark plugs and wires, but I have a problem with the jerking of the car. It might be a miss fire, which leads me to believe the wires are bad. Now when I unplugged the timing connector I was able to Time the car to where its supposed to be and then I plug the connector back in and its fine, minus the jerking. The trouble starts when I turn off the car after plugging the timing connector back in, it advances the timing and the check engine light goes off. I cant seem to get the PROM chip to reset like i thought it would and I cant have the car running without the timing connector connected. Is there a way to solve this problem? PLEASE REPLY...............thanks
Old Mar 26, 2007 | 12:22 AM
coprunr's Avatar
Default RE: I dissconnected the timing connector......
disconnect the battery for at least 20 seconds. that resets the PCM. and also , your suposed to turn the car off , then reconnect the connector. unplug it with the car off and plug it in the car off, not with the engine running or the key on.
Old Mar 26, 2007 | 05:06 AM
ORIGINAL: coprunr
thanks, ill have to check it tomorrow..also do you think the jerking could be from the old spark plugs?I checked one and the gap is a little wider than it should be, but the burn color is clean. It hasnt had a tuneup for at least a year. If I change that I know I will get more power back as well...
Old Mar 26, 2007 | 08:44 PM
coprunr's Avatar
start with a good tune-up... plugs, wires , cap, rotor, air filer, pcv valve, and fuel filter. if that doesn't help, at least you know all that is good.
lvchev
Jul 4, 2010 11:46 PM
ScottD
Mar 18, 2010 12:36 AM
waffles
Sep 14, 2009 04:14 PM
BlackIceZ28
82-92 V8 Tech
Mar 26, 2007 11:42 PM
sewerrat
Mar 23, 2007 04:29 AM
