Hmm what to do...
Old Jul 5, 2006 | 03:17 AM
Withered962's Avatar
Default Hmm what to do...
Got a 88 IROC which as you know comes with the 350, i get around like 240 hp?? and 330 lbs of torque?? rough guestimate there... I'm pretty sure about that tho.
Anyway, any suggestions on uping the HP?
suggestions as in what headers what cam shaft what heads....
So yeah... can i get a guestimate on the HP with the input you're going to put in, and also a good trans. cause mine needs to be replaced...badly
thanks
~Mike
Old Jul 5, 2006 | 10:31 AM
blackz87's Avatar
Default RE: Hmm what to do...
Well get the Tranny fixed first. (A big buck item depending whats wrong with it).
Also you are high on the HP estimate, 230 stock for 88 350TPI.
The easy wayy to increase Hp would be:
Headers 1 3/4
New hi-flow cat 3"in/out
3' catback exhaust (mandrel bent pipes)
SLP style intake runners
These bolt on should give you about 20 to 40 HP over stock.
Plus a good tune up with new plugs, wires and etc. Will make sure you have the HP that came stock.
I would wait unstill you need a rebulid before the Heads & Cam and complete the above first. My opinion.
[IMG]local://upfiles/2696/311D18F4A0C447B08EBE81021DA3C2CE.jpg[/IMG]
Old Jul 5, 2006 | 01:10 PM
what type of headers r we talking aout, ceramic tri y's?
and i've been looking for an exhaust system, no one seems to be selling anything for 3rd gen camaro's, know a good site?
Old Jul 5, 2006 | 01:23 PM
Try Summit or Jegs, they have good assortments. In essence there are two types of headers, shorties and long tube. The shorties are easier to install but produce less low end power than the long tube. The materials and coatings used affect longevity , but have little effect on power produced, although ceramic coated headers are claimed to produce a few extra horses. I doubt that it will be noticed by the butt dyno. As for power output, one make is about as good as the other, but there are big differences in quality, and you get what you pay for.
Old Jul 5, 2006 | 04:09 PM
blackz87's Avatar
You could click on the highligthed (exhaust) in your reply and do a search. It took me less then a minute to finds sites for 88 350 Camaro.
