hissing comeing from the dash
Old 12-09-2009, 09:36 PM
concept225's Avatar
Default hissing comeing from the dash
I hear a hissing coming from dash. It always hissed but everything used to work. The a/c blows cold air and the heat blows hot. Just recently the air only comes out of the defrost vents no matter what setting i put the switch on. Heat, vent, norm, all comes out of the defrost vents except for the the max cold setting that still comes out the main vents. Im curious if the entire a/c /heat deck has to be changed or if it is something else? Also i have noticed that when i put a strain on the motor the hissing goes away. Basically i would like that hissing to stop and the switch settings to work correctly so if anybody can explain why this is happening it would be greatly appreciated ..Sorry for the length of this post
Old 12-09-2009, 09:41 PM
mtn_maro's Avatar
sounds like a vacuum line to the heaterbox is disconnected
Old 12-11-2009, 12:47 PM
MegametedK's Avatar
Yep, sounds like a vacuum leak.
Old 12-11-2009, 08:05 PM
microkid's Avatar
March 2011 ROTM
Technical User
yes, vacuum line is off or broken somewhere, or it could be the entire control peice. defrost is the default, no vacuum position.
Old 12-11-2009, 08:07 PM
Adam78's Avatar
what they said
Old 12-11-2009, 09:16 PM
mighty mike's Avatar
im not sure if its been metioned, but i think its a vacuum leak.
Old 12-11-2009, 10:56 PM
mtn_maro's Avatar
you know? i think he might have a vacuum leak. nobody ever thinks of something that small
Old 12-11-2009, 11:27 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Have you checked the vacume lines?
Old 12-12-2009, 10:51 AM
It could also be one of the suck hoses that's connected to the heater controls. They're driven by vacuum!!!
Old 12-12-2009, 12:39 PM
concept225's Avatar
so i did some tinkering and it turns out...it was a vacuum line. well done everybody
Camaro S
05-23-2013 12:49 PM
Hazard29
04-28-2011 02:47 PM
auto
11-02-2010 08:00 PM
dopez28
08-16-2010 07:57 PM
94.V6.VROOM
05-21-2009 04:28 PM
Quick Reply: hissing comeing from the dash
