helpp!!!!!
Old Apr 17, 2012 | 10:02 PM
87 camaro z28's Avatar
Default helpp!!!!!
So I was having my car run rough I found a faulty plug when I pulledi out it had oil on it I know its either the piston rings or the valve seals but I have not seen any blue or white smoke but the engine seems like its lost some power and has trouble accelerating what's my best bet??? I did notice some oil residue on the valve covers???
Old Apr 17, 2012 | 10:03 PM
When. I pulled the spark plug
Old Apr 18, 2012 | 12:15 PM
Oil and other gunk on the plug is normal if the plug isn't firing. Find out why the plug is not firing and replace it. As you noticed, the engine gets a bit weak with a dead cylinder.lol Start by replacing the plug and plug wire and go from there.
Old Apr 18, 2012 | 02:32 PM
Thank you Pete what are some other possible causes of the cylinder not firing?
Old Apr 18, 2012 | 03:27 PM
djs383's Avatar
I can't say for sure, but you need a good spark, proper fuel and air mixture, and compression. Check compression on that cylinder to rule that out, then start looking at ignition (plugs, wires, rotor, etc) then if FI check injector to that cylinder. A quick note on spark...you can have what looks like good spark and sometimes under compression it can be much weaker than you had thought.
Old Apr 18, 2012 | 05:41 PM
Spark plug and wires are good??? And my oils consumption is normal???
Old Apr 19, 2012 | 11:25 AM
djs383's Avatar
Have you checked for compression yet? Have you run any other ignition or fuel delivery diagnostics yet?
Old Apr 20, 2012 | 10:27 PM
It was a fuel injector fixed it
LT1Ron
Apr 4, 2012 05:06 PM
ChrisSmith
Jul 29, 2009 08:41 AM
Camaro_Boi69
May 11, 2008 11:14 AM
camaro89rs
82-92 V6 Tech
Sep 24, 2007 10:23 PM
jhop16
Jun 16, 2007 03:20 PM
