Help t-5 gone whack!
you can do the tranny mount in under an hour. 30 minutes if you hurry. It is the rubber piece under the tranny. You undo the the center bolt to the mount jack the tranny a bit undo the center support take it off take off the mount put it back on. I havent done it in about 10 years, since I owned my trans am. It may not be exactly that simple but close. take a look and see if it looks that way, make sure there isnt extra stuff I failed to mention.
also I hope that if your motor really is 375 hp then you have frame rails(sub frame connectors, whatever they are called) installed.
ok so its the piece between the tranny and the crossmember right? Since the tranny has a dead syncro in 1st and 5th im just going to drive it like a house of cards until i can put in the connectors and a t-56. thanks for the help man
