Help please 90 Iroc fan won't go on
Old Jun 20, 2014 | 06:41 PM
Bobby V's Avatar
Default Help please 90 Iroc fan won't go on
My 1990 Iroc overheated busted the lower hose. After replacing hose, coolant switch and thermostat still overheated. My buddy rigged up the fan so it would go on then no prob. How do I fix it so fan will go on by itself??
Thanks Bob
Old Jun 20, 2014 | 07:36 PM
ECM looks at coolant temp sensor. when coolant gets to around 220, the ECM operates the fan relay, which in turn provides power to the fan. Make sure the fan relay works, and that the ECM grounds the relay control leads when the temp is high enough. Try to get a wiring diagram for your car.
Old Jun 21, 2014 | 07:29 PM
Bobby V's Avatar
Thanks so much your a great guy, god bless you and your wife🙏
Bob
adam86107
Dec 8, 2011 06:52 AM
Kyric
Mar 24, 2009 04:09 PM
74454bb
82-92 V8 Tech
28
Nov 4, 2008 02:57 AM
JIROCZ
82-92 V8 Tech
11
Aug 26, 2008 04:12 PM
BLACK 89 IROC Z
82-92 V8 Tech
Aug 8, 2008 06:21 AM
