Help....please
I have a 91 rs that will start one day and the next it wont. the battery is new, the starter is new,the distributor is new, the ignition module is new. ive checked all connecters and wires, and no signs of anything bad. Im at a loss. Any ideas what this problem is?
My friend just had to bypass vats on his daughters 96 trans am. Same thing, they thought it needed starter, was just vats. Cost 10 bucks to bypass with resistors from Radio Shack. Do search on forum for fix, that's what they did.
If it is the VATS, you should be able to start it after 10 minutes. If so, then replacing the ignition cylinder is a better way to go. A loose key/switch connection will trigger the vats and disable the car for 10 minutes. A standard cylinder won't do. It needs the wire connection for the vats, but can be bought at most auto parts stores. You will need to get key blanks at a dealership. They will need your old key to measure the resistance. Any key shop can cut them to match the non resistor key that comes with the lock. Sure you could just bypass the vats, but then you have no vats.
