HELP HER BREATH!
Old Apr 11, 2007 | 12:57 PM
StratcatDeville's Avatar
Default HELP HER BREATH!
Okay okay......like im sure most of you know, the LO3 TBIstock intake is a freaking straw! Are there ANY cold air intakes for it I could get out there, or would an open element be alright? And if the open element wouldnt be too bad, what kind of bottom would it need to fit over the TBI...any specific ones maybe?
Old Apr 11, 2007 | 03:37 PM
hurley870's Avatar
Default RE: HELP HER BREATH!
Not sure about the cold air intake, but I found some info on the 305 TBIs when I got mine.
Check out:
http://www.goingfaster.com/spo/spo_t...y_central.html
It's a lot of reading but it helps.
Old Apr 11, 2007 | 06:15 PM
ORIGINAL: hurley870
Check out:
Yeah that was where I got the ideas...but im still not sure. I figured there wouldnt be a cold air intake made for it because I couldnt find any on the internet but I figured it was worth a shot to ask here.
Old Apr 11, 2007 | 07:04 PM
92camaroRS's Avatar
Yea i was in the same boat as you. There are no c.a.i. so your only option is to get a open element air cleaner. Your gonna want a 14 in wide and 3in tall one. Also it must be a drop base, which means the bottom of it is gonna enclose the trottle body, so itll clear the hood.
Old Apr 11, 2007 | 08:31 PM
MadMikeZ28's Avatar
If you want a little more air with your stock cleaner there is a shield inside around the TBI that has 3 or 4 spot welds. Grind the wels down and rip that shield out.
Or
Look for a CAI for a TBI truck. You will get the intake hat, a tube and filter. You may need to add an angle tube or do some modification. I have seen some parts in pep boys right on the shelf. And a trucks CAI off ebay should not be too much.
Old Apr 11, 2007 | 08:56 PM
Zdc590's Avatar
Edelbrock part # 1207 is the most common. Its a real quick install and a huge improvement over stock.
Old Apr 11, 2007 | 11:40 PM
coprunr's Avatar
www.cfm-tech.com they sell alot of TBI performance parts.
Old Apr 11, 2007 | 11:42 PM
Wow thank you guys so much!
Old Apr 16, 2007 | 01:50 AM
mongo's Avatar
you could costom make a ram air kit for your self
Old Apr 16, 2007 | 02:01 AM
sammyrocker5150's Avatar
or do what i did, take that gold ish spacer that is about 3 inches tall on the tbi, and take it off, and then use a drop base aircleaner so you can go 14x4 instead of 14x3.
