HELP
HELP
ok so i got a 350. and im starting to get pissed theres oil leaking onto the top of my axle and fuel pump badly on the passanger side but i can not find where its coming from. its not coming from, the fuel pump, valve covers, intake manifold, where the hell else would oil coming from to get into those 2 spots.
RE: HELP
i have no idea what its called... but there is a small platic line on the back of the intake. It has a brass fitting. Thats about all i got for a discription, sorry. But ive had that leak on both my 68 chevy, and my 89 RS. Just tightened it and all was fine again. Maybe try looking for that?
RE: HELP
exactly thats what happened i cleaned it up good. drove it and wind just blew it everywhere again. well tomorrow my dads taken it to his job gonna degrease it all on his lift and find it thanks the the help ill let u guys know what it is tomorrow.
RE: HELP
if it leaking from the fuel pump area? if so look on the front of the block by the fuel pump boss...there is a threaded hole there that goes into the fuel pump boos..if there is not bolt there it will leak like crazy because it goes all the way through to the fuel pump boss
