Headliners
i was looking at my dome light the other day, How do you get it off? i can pop the plastic off, but then all i see is a pop rivit type deal holding them in, how do i get them off?
This place has it and a lot of other parts you might be looking for.
http://hawksthirdgenparts.com/
www.nextgenparts.com www.classicindustries.com
The dome lamps have one way type of clips. You can try to twist the off orbreak them off. They are ment to go on one way and not come off. They are like the retainers you find on the stud of drum or rear disc brakes if they have not been removed for the first time.
Those clips will come off of the studs. If you dont break them reuse. If they do break some autoparts stores sell them in the area with the body speed nuts and stuff. They may look flat or round but do the same thing.
